1993 sportsman 4x4 350 Awd help
Old Mar 3, 2009 | 04:51 PM
kaptn12's Avatar
Default 1993 sportsman 4x4 350 Awd help
When i engage the button the Awd light stays on while in high but, for some reason the left fron tire does not pull. I jack ed up the bike and did this i can hold the left front tire front spinning. I changed the oil in the hub. What is my main problem a new hun or bearings? Thanks
Old Mar 3, 2009 | 09:09 PM
Check that power going to gray wire into left strut when in gear and awd switch on! If has power then possible internal problem in hub. Should be SMALL gray and brown wires tieing in to terminal board (under tank cover on drivers side)
Jmuddin284
Jan 19, 2026 07:16 AM
cornermike
Aug 10, 2016 06:47 AM
79hugger
Aug 30, 2015 02:21 PM
dwhipper61
Aug 27, 2015 11:01 AM
338 lap mag
Technical and How-To Articles
Aug 2, 2015 03:57 AM
