Are the K&N Filters worth the extra money?
Old Mar 20, 2009 | 11:19 PM
  #31
knezz's Avatar
Default Are the K&N Filters worth the extra money?
<div class="FTQUOTE"><begin quote>Originally posted by: DCT
<div class="FTQUOTE"><begin quote>Originally posted by: knezz
I had oil saturate my paper oem air filter (still trying to figure that issue out) therefore I need to replace it.
Are the K&N filters worth the money?
Do they affect performance?
If oil hits them can they still be cleaned?</end quote></div>
knezz,
You need to get to the bottom of the problem with the significant amount of oil getting in the oil box, or it won't matter what filter you choose, as something is wrong?
Did you/do you roll the quad over or on it's side frequently?
Is the breather blocked?
Is there too much oil in the quad?
On a side note, I see your "Recon" avatar. Are you/were you a Recon Marine?
If so, Semper Fi from an "old" Recon Marine.
1st Recon SSD</end quote></div>
I haven't seen the problem since I cleaned the air box and replaced the paper filter with the K&N.
Note: I purchased the 2007 Predator used from a dealer. It was a trade in.
I guess I was anxious to ride and only checked the oil and the other fluid levels. The oil was a little high but I attributed that to checking the oil after the unit was running for more that 20 min. I didn't inspect the air box. I was taking the quad on and off a pickup (using a rather short ramp). I didn't turn the fuel off when doing that either. I've had 2 decent runs since the problem. Nothing negative happened so far. If there was too much oil (which could have been the case) it isn't now as a good amount was cleaned out of the air box and was saturating the paper filter. I never rolled the quad but who knows what happened prior to me purchasing it.
Esprit De Corps - 22nd MEU
Old Mar 21, 2009 | 06:56 AM
  #32
DCT's Avatar
DCT
Banned
Well, I'm glad everything seems to be fine now. Just keep an eye on it, and ...
OO-RAH!
lightninboy
May 16, 2021 09:52 PM
STLyamwar
Jul 25, 2020 04:44 AM
nachop
Feb 14, 2018 06:57 PM
Ronk407NY
Feb 13, 2016 11:05 AM
metal249
Jul 24, 2015 01:00 PM
