Polaris spring spacers Sportsman
I installed the rubber spacers on a few of my quads over the years and like someone wrote it was the best $12 I ever spent.
I did it to prevent the front from sagging so much while plowing snow and to eliminate nose-dive in moderate speed corners.
Install them in the middle of the spring.
To really toughen things up I put 2 sets on each side up front and it was perfect for my needs on my old X2!
Also a few other thoughts to keep in perspective and HDDOP, hit it right on and that is the type of riding and terrain you do. To be honest when I made my front HD Spring Mod it was for the Snow plow reasons and to address the common Sportsman "Sag". But never for the life of me would I suspect that my rear was not set and when I sit down the rear squats too much and the front is noticeably higher. I had NO idea about the center of gravity thing when it came to the mountain trails. Again many factors contributed to my spill but please please address both when you improve one or the other.
Your situation could be mine or HDDOP's with the rear. So make certain your configurations (riding weight+cargo weight ratios to spring adjustments) are right and your overall center of gravity is dead on.
Sorry for the repeated advise, but I think its something never talked about in these threads. I think I need to do more with mine, EPI's or something.
Regards,
R'
Regards,
R'
Coil Spring Spacer from Polaris ATV Accessories & Apparel 2006
bzdok1234
30
02-23-2016 01:55 PM
