97 Explorer 500 hubs.
Old Dec 22, 2009 | 01:44 PM
UP Rider's Avatar
Default 97 Explorer 500 hubs.
Just serviced the bikes for storage. On going thru front hubs, I noticed not much for lube in the right side and some moisture. I forced grease thru and got the moisture out. So now its full of grease and not fluid. Any one know of any drawbacks to running grease instead of fluid? It shifted in and out of 4 in my heated shop just fine.
Old Dec 22, 2009 | 04:28 PM
4getful2's Avatar
i don't know that the hiliard clutch will work correctly when used in the cold,but you said storage so....... you may have to take that side apart in the spring and use some degreaser. if you don't have any polaris hub lube, you can use type "f" auto.trans.fluid as a substitute.
mattcraig1
Aug 26, 2015 03:08 AM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
blaze_master
May 26, 2015 11:18 AM
WIscrambler
Jan 22, 2001 07:32 PM
keithb
Sep 13, 1999 10:09 PM
