Fuel warning light flasing on Polaris 500
if it comes to that. and it has no warranty. take the sending unit out, and bring it to an automotive place parts place like napa or car quest or and o'reilly's autoparts store and match it for ya. you can get one there for around $100 the same pump i beleve was used in a 90ish yr toyota pickup or something like that.
Thanks Mongral and Chuck R. Chuck R., my 500 is a efi, but I would like to see the photos you made of your sensor. I bet they are the same, and if not, at least it gives me an idea of what I am looking for. How did you get the sensor out of the tank? Sewnd the phots to fzorn1@aol.com if possible...
Mongral, I will give this a try if all else fails...thanks for the info..... Fred
#15
pump
I have taken a few apart. take front box off then front fenders to get to the tank then you can get to the tank.We usally take a stiff wire and look in the tank with a flash light and pick up on the float arm with the wire to see if that changes your fuel level reading.If tanks very full you will need to drain your tank down some pumps in right front corner of the tank.So look toward the front of the tank for the arm.
#17
whitty
67
02-24-2021 02:52 PM
05-27-2015 11:15 AM
