sportsman 400 will not shift out of 4wheel LOW
I was using my 400 to pull a light drag (80-90lbs)to make some tails. I was pulling in 4 wheel low. When i was done i tried to shift it into neutral and into high or reverse and it wouldn't. It was stuck in LOW. I tried rocking the atv, applying the brakes,... I was on flat ground and no pressure on the transmission. Any input would help thanks. I don't want this problem on the trails this summer.
Once you get the trans unstuck and have in neutral,loosen the locknuts at the small ball end of the shift rods on the shaft and remove shift rods from shifter box. Turn linkage ends out or in until the ends DROPS STRAIGHT into shift arms of shift box. This can help stop the gear locking(hydrolocking) in the future. I have to do this procedure a lot on older machines as the shift box begins to wear and has slack.
KimSJoh
14
07-18-2015 07:20 PM
