2002 Magnum 325 HDS reverse kills engine
Hi
I have the above and when I put it in reverse without holding in the override button the engine dies, if I remove the black wire from the speed limiter, as found by searching the forums, it still does the same. Anyone have any ideas?
Thanks in advance
Colin
Thanks in advance
Colin
Fixed it
After talking to my local Polaris dealer this turned out to be the speedometer at fault, disconnecting the wire to the wheel sensor at the speedometer the problem went away. It seems that if the speedo is fitted it controls the reverse speed, mine had got moisture in and the speed reading fluctuated a lot which made it think it was going to fast in reverse.
Hope this helps some one in the future.
KimSJoh
14
07-18-2015 07:20 PM
