Why not leave a Polaris in AWD all the time?
Old Jul 16, 2010 | 12:54 AM
TLC's Avatar
TLC
Originally Posted by 94harley
I would think it would wear out the armature plate(or plates depending on year) quicker. With it in 4wd all the time the magnet is energized and causing drag on the armature plate to the coil face, In 2 wd it still probably makes contact but not with magnetic force pulling in on it.
I would go with that reasoning.
Very bad on the old wheel hub style awd design. One wheel lock up would cause you to loose control
Both the newer single diff Hillary and twin hub Hillary make both front wheels to lock at all times when engaged.
The new single diff design with the exploding single roller cage sounds more spooky,than the older twin hub set up if I had a choice.
Old Jul 16, 2010 | 08:15 AM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
leaving it in awd also effects engine braking down a hill and makes it hard to power slide around corners.
Old Jul 17, 2010 | 11:22 AM
NBsportsman's Avatar
In my mind Polaris has the most ingenious 4X4 system out there switching from 2 wheel to 4 wheel drive automatically when there is a little rear wheel slip. This is my second Sportsman and my AWD switch is always on.......
Old Jul 17, 2010 | 01:06 PM
TLC's Avatar
TLC
Plus when it is in 4wd its true AWD like diff lock ,not this 3wd stuff.
Old Jul 20, 2010 | 01:38 AM
  #15
mrtwostroke's Avatar
he is refering to an unwanted engagement of one wheel. Caused by a broken or weak retainer spring in the front hub style.
whitty
67
Feb 24, 2021 02:52 PM
MikeyBoyesq
Nov 27, 2020 02:44 PM
neilbedwell
Nov 10, 2018 11:02 AM
tycobb
ATC 3-Wheelers
Oct 23, 2015 07:37 PM
WilliamBos
Sep 30, 2015 08:08 AM
