Remove starter on '03 500 Sportsman?
does anyone know how to remove starter motor from my 2003 Polaris sportsman 500 HO? I have disconnected the 2 bolts in real starter housing and both + and - wires. If it is just splined into drive gear shouln't it just pop out? Does the drive gear have to come out of the housing with it and if so how does that happen without removing the recoil case etc.?
The 500 starter is on top of the motor, the 400 is on the bottom of the motor and yes, the 400 needs the recoil removed, but the 500 does NOT need it removed to get the starter off.
There is an oring on the recoil end of the starter that can hang up on you. Tap the starter out from the right side and it should come out.
Yep. the bendix will not move. just pull the starter.
KimSJoh
14
07-18-2015 08:20 PM
