Ball Joint / Wheel Bearing Torque?
Old Jan 31, 2011 | 08:29 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
Question Ball Joint / Wheel Bearing Torque?
2005 SP 500
Just replaced ball joints and wheel bearings.
Torque value for ball joints?
Torque value for Hub castlated nut?
Old Feb 1, 2011 | 08:22 AM
JCDEYO25's Avatar
These specs are from my '05 700 manual...not sure if the 500's are the same...front hub nut: 70 ft. lbs... rear wheel hub nut: 80 ft. lbs....front a-arm ball joint stud nut: 25 ft. lbs.....
John
Old Feb 1, 2011 | 10:22 AM
weedy's Avatar
sweet. Thanks for the help
Old Feb 19, 2011 | 10:21 PM
bjones12's Avatar
How did you get the ball joint out? I've been trying for hours
Old Feb 19, 2011 | 11:23 PM
switzomatic's Avatar
Remove the grease zerk on the strut if you have one(gets rid of the vacuum effect while removing and installing). Light heat on the housing usually helps and/or slide hammer. I have also used an old bearing race or equivalent a little bigger diameter than the housing it sits in then slide a box end wrench or preferably a balljoint seperator (if you have one-they come in handy)smaller diameter than the castle nut on the threaded portion. Put the castle nut on and use an air wrench to tighten while utilizing the wrench as a fulcrum. Should pop it out. Put the new one in the freezer for a little while before installing and it will go in easily.
Old Feb 19, 2011 | 11:35 PM
bjones12's Avatar
Well I guess I should have given you a little bit of background info... The pin that sits in the ball joint (what you put the castle nut on) has come out. So all I am left with is the ball joint housing stuck in the strut housing. Hope that makes sense.
Old Feb 20, 2011 | 10:20 AM
weedy's Avatar
My onlt suggestion is weld a bolt to the piece in the joint then us a threaded puller to pull it out.
Old Feb 20, 2011 | 11:22 AM
Kerbbirds's Avatar
A propane torch to heat the strut housing, as stated , weld a bolt to whats left, I usually heat the strut then put vice grips on the ball joint bolt and hit the vice grips with a hammer when the strut gets hot they will come out, have a deep socket the same size as the new joint , slide over bolt and tap in while strut is still hot
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 12, 2015 06:42 AM
toonces
Aug 5, 2015 05:55 PM
Peter_
Jul 18, 2015 07:06 AM
musselmark
Jul 17, 2015 02:40 PM
