AWD Doesn't Work On 2004 Polaris Sportsman 400
I took the plug loose from the AWD switch and cleaned, did not help. I also tried grounding the Brown/White wire from the AWD switch, did not work either. I guess that Brown/White wire is in the harness from the AWD switch? If not, is there one in the large plug on the back of the speedo? You mentioned the sensor could be bad. Where is it located?
#15
my speedo has two plugs also,but one has 3 wires and the other has 11 .what wire needs to be grounded for the bypass to work,
2004 sportsman 400
...cant remember all the colors,but the larger plug has atleast 3 browns,the smaller has no browns,dont quote me on the colors,but will check for sure next time i open the pod
2004 sportsman 400
#16
#18
Have you tried the hub wire grounding first?
#19
As well as the Speedo, the AWD light on the switch must work also. I never tried the speedo by pass trick but I hear it works. I would try it it before buying a $300 speedo also.
Here is the best info about it by "Ditchdigger" I could find on it. http://forums.atvconnection.com/pola...dont-work.html
Gents, I recently bought a 04 400. When I flip the awd switch the indicator lights up fine. The front drive shaft engages and both cv axels turn. I lifted the quad off the ground with a jack. The rear tires get power but the front does not. With the drive shafts engaged and the cv axels turning. The hubs won’t turn though.
All help appreciated.
whitty
67
02-24-2021 02:52 PM
