2005 800 Sportsman EFI sputters
If you do have a t-bap harness problem(big IF), a lot of times NO codes will show on speedo OR even "false" codes may show up.Even hooked up to Digital Wrench, codes don't often show up unless a positive break in wiring! Even have had plenty of codes"21"(loss of synchronization) and "23(bad ECU) show up on the speedo!! One way is to feel the wires and if you find a "soft' spot in the wiring,possibly could be the bad wire. Also you can try the "jiggling' method one Polaris engineer suggested! While running in neutral at higher speeds,jiggle the wires and see if you notice a change in the engine! Sounds squirrely,BUT I did find one t-bap harness problem this way! Plus to reset the codes just disconnect the battery for a few minutes. After all this my best guess is still the t-bap harness since the usual signs are spitting,sputtering and this is what we replaced the most of on the 500,700 and 800 efi machines. OPT
Ok, so last night I took your advice OPT. I felt for weak spots in the harness wires, but I didn't find anything. I wiggled the wires and found that if I held the wires in a certain position it would not bog down when I mashed on the throttle. Am I assume that the wire harness is shot???
Replace with either the oem or after market t-bap harness kit and hopefully will solve your problem. BUT can't guarantee how long the oem one will last!! (not until they address the small wiring on all the sensors and the kits also) OPT
#15
Yes,should be showing 39 psi. May have found the problem! Not from the t-bap,but could be a fuel pump problem. Does it still change when you mess with the wiring also?? Could have a double problem? OPT
Shifts
14
Jul 13, 2015 08:41 AM
