Polaris sportsman 700twin 2003
#42
Each yellow/red striped wire had a corresponding yellow/red stripped wire to plug into so I just plugged both of them in.
It runs fine.
Should I go back and change anything?
Thanks
Bubba
#43
First check that it's charging okay back to the battery at an idle if it runs good. Should be 14-14.5 volts on average.If it charges okay leave it the way you have it. Both yellow/red wires are from the stator for the regulator/rectifier and may just have a junction where the wire splits into two,but still from the same source. Been 3 years now,so my memory is a little foggy. The instructions are a little vague also about the jumper harness wires to use also.
#44
So I should be good or should I go ahead and check it at the battery?
Thanks
Bubba
#46
So I guess I'm good to go .....Thanks old polaris tech
Bubba
bzdok1234
30
Feb 23, 2016 01:55 PM
