02 Sportsman 700 -- Plugs?
No, you just need small hands. It is easier (not easy) to access both from the shifter side of the atv. It is a definate knuckle buster to get in there. I usually put the end of the socket on first then snake the rachet thru evrything to get it to the socket. Not much room to manuever.Make sure you clean the area around the plugs so that packed mud and dirt don't go inside the motor.
KimSJoh
14
07-18-2015 07:20 PM
