2008 sportsman 800 dead miss
May be coincidental but did you check the charging system? 14 volts going back to the battery. Plus it could be a T-bap sensor harness intermittent short,common for efi machines. You might also just take a sample of gas and see if any water settles at the bottom of a clear glass. Had a few like this and would exhibit a dead miss also that you could mistake for an electrical problem. OPT
Just because you put a new battery in your ATV does not mean that the new battery is 100%. I have seen brand new battery's faulty out of the box so you may want to start there. Also check to make sure that the connections are installed correctly as some of the ATV's have a second wire on the positive post and it gets missed when replacing the battery as it is hidden under the plastic proctector.
bzdok1234
30
02-23-2016 01:55 PM
