2002 Polaris ho 500 starter will not start it?
I am stumped had a bad battery replaced it, starter solenoid was replaced and a new starter .The bike will start on the pull cord runs great charges the battery no problem. I am thinking I should try another starter solenoid the old starter was locked solid an had to be replaced and the the battery had to be replaced. Is there something I am missing??? There must be a broken wire some place??? If anyone has any ideas let me know. I've been on this site before and have saved money and repaired my machine myself and if there is a right place to ask this is it.If anyone has an idea let me know.
Had one member that went through the same problem. His cure was to sligly move the pulse coil closer to the flywheel. He could rope start it,but couldn't elec start until he did this. Not really any room for adjustment,but you can "Lightly" tap the pulse coil a bit closer to the flywheel. OPT
This seems like it's starting to be common problem on the 500 from either rope damage, trash,plus sometimes just from age.This member had the same problem,could rope start,but not electric start,but was caused from recoil damage. http://forums.atvconnection.com/pola...ml#post3155476
OPT
OPT
That's why I removed the cover to clean up the pull cord so it would return properly and yes I should have glued the pull cord .I have glued it in the past but it slipped my mined this time .This pulse coil should I replace it or make the mounting holes a bit bigger so I can move it closer I know where the location of pulse coil is sucks I have take it apart again.Before I do this I am going to jump the pins on the starter solinoid .Just to see .In my manual it indicates the pulse coil as you call it as the trigger coil #3 under Ignition system. I will have a look at it.
Check the face of the pulse(trigger coil) for any trash as mentioned. If it's clean and the flywheel doesn't have any rust/corrosion on the out side,just "lightly" tap the bracket itself inward(which will move the pulse coil too) just a little toward the flywheel.There's really no room on the plastic pulse coil to enlarge the holes without taking a chance on cracking the mounting tab. I had to do this on an old 500 6x6 years ago when I had the same problem on not being able to electric start,but it would recoil start.I just gave it a little tap inward. Then you can seal the recoil handle if you wish,plus make sure you run a good bead of rtv(Yamabond or Three Bond) around the cover itself. Hopefully this will solve the problem.If not then you need to check the resistance on the white and white/red pulse coil wires.I believe it's 97 ohms on this model.If too far out of spec it may need to be replaced. OPT
Thanks for helping everyone went out to the garage and had another crack at it. I decide to try the starter solenoid by jumping the pins and it fired right up the starter solenoid is new .If it fired up by jumping the pins on the starter solinoid then the trigger coil is ok. Is this correct ? If it's the starter solenoid then I will run to the dealer and get another one.I appreciate the help if nothing else I am learning lol a few things...
