550 touring - ricochet/plow conflict?
I also called the ATV superstore and they reccomended the Eagle Mid Mount setup for the 550. It is supposedly stronger than the front mount, as they have seen some front mount frame damage from front mount plows on this ATV.
Also the universal mounting plate can bolt up over the ricochet skids.
I am just a little concerned I will have plow lift height problems with mid mount. Anyone know how high you can lift a mid mount plow?
I got about 14" of clearance after I put on the limiting switch that shuts off the winch when it's lifted so it doesn't damage the quad or winch line. Maybe had 15" before. That's on a Can-Am Outlander with probably about the same clearance as the XP. My plow mount hooks up to a pair of pins mounted on a plate flush with the skid plates I put on. It's just behind the front tires. So any mid-mount would be around the same if the plow frame has straight tubes. If the plow frame has tubes that angle up once you get beyond the front tires you might get a little more lift.
Do you have an Eagle plow setup? Their stuff looks well built and is American made which is a plus.
14" is pretty good plow height I guess. Is there a reason people are so concerned about plow lift height? I would just be worried taking out of my shed, as the ramp is on the steep side and I wouldn't want to bottom out the plow at the bottom of the ramp. Can't imagine that would happen with it up 14".
Thanks for the info Moose. What is a limiting switch? Hope that isn't a stupid question. I know I have one of those rubber stoppers to protect the fairlead.
The instances when you want a little more lift are when you have the blade lifted a bit to push the top of a snow pile over or when loading and unloading. If you have the blade all the way up when you're knocking the snowdrifts down you can end up not being able to back up if the plow sinks into the snow. Had to dig out one time for that.
I need to find a picture of a mid mount plow raised up. It is hard to picture 14 or so inchs of clearance.
The connection for the Eagle front mount just doesn't look that strong for the 550 unfortunately. Too bad as I would rather have that setup. More compact for storage and good lift height.
Only other option is the Warn front mount, but from what I hear the Warn stuff isn't made as well as the Eagle stuff. The Warn front mount for the 550 actually looks better designed than the Eagle 550 front mount.
Maybe I'll get lucky and someone here will have plow experience with the 550.
