scrambler 400 wont start and back fires
Old 02-10-2014, 05:37 PM
Gavman9966's Avatar
I have a 01 Blaster thing wouldn't start its too much air getting in head maybe u blew a head gasket? or ur reeds could have a small crack
Old 02-11-2014, 08:55 AM
Originally Posted by Connor Schuster
Does ghis explain why it bacjfires
It's one of the symptoms that I've encountered on low compression engines. Some times fuel loads up and ignites in the exhaust system. I've had a lot of head pipes blown off the springs. Sometimes they'll back fire through the carb.Plus is the crank seals are leaking you'll have more fuel than air try to shoot up the transfer ports. It can foul plugs or pop back if this excess gas happens to ignite. You have to have good top end compression along wth good bottom end compression(seals) to be able to atomize the fuel mixture properly to ignite. Another test is using starting fluid. A lot of machines may start on it and die when it runs out as it's lighter than the normal gas/air mixture.
TegraQuad
1) Engine problems..
13
11-26-2017 01:40 PM
armpump450r
Technical and How-To Articles
04-01-2017 06:11 AM
dnm48
06-14-2015 10:11 AM
Steven Bandemer
05-27-2015 07:39 PM
400freak
03-27-2000 05:33 PM
Quick Reply: scrambler 400 wont start and back fires
