did i just blow my sportsman up??
The vent line at the very top of the oil tank. When you do prime a pump,this hose has to be clamped with a pair of vice grips close to the tank nipple because of a small condensation slit in the hose about 2 inches out from the tank.Crank the machine up and after a couple minutes you can pull the vice grips off. If you have good ears you can usually hear a hiss of air from the tank. Again I only did this when I cleaned tank screens or on engine rebuilds. Just run the engine,you'll be able to tell real quick if something is wrong. Hopefully again it's a clutch problem,but you never know on a used machine.
Doesn't hurt a bit to use 5w50. Plus that's what weight you get in PS4 Polaris oil now.http://polarislubricants.com/atv.asp
#15
Went for a half hr ride this am..i am stumped, started fine no smoke typical fuji 500 motor noises.ran fine the whole time with out a drop of smoke or power loss or noise.only thing i noticed is a flat spot in the belt from coming to an aprupt hault..again i am stumped
#16
Have you cleaned the clutches?
