scrambler bogg
Old Jan 8, 2016 | 01:16 PM
  #51
scram5050's Avatar
You're getting too far ahead of yourself!! Fix what you know is wrong first:carb and clutches,possibly new drive belt. Then concentrate on electrical if problem persists. It's called process of elimination..
lol.. ya i kknow this atv just hurting my head lol...
i ran out of gas yesterday in it so i looked in gas tank and its filled with crumbled leafs and crap like sand and dirt so thats awsome lol.. and
also was starring at my clutch and notice along the spider there is a long crack dosent look deep but im guess whole new clutch will be needed in a year or two for now will just put kit in it..
Old Jan 8, 2016 | 01:23 PM
  #52
Good time to flush it out and check or replace the inline filter.
Old Jan 8, 2016 | 03:41 PM
  #53
scram5050's Avatar
ok will do is the inline filter the white thing after the fuel pump leading to the carb?
also opt the reason i asked about what else could be causing bogging is cuz the atv only used to bog when HOT it usally ran fine till the anti freez would spray out of over flow bottle then thats when the bogg woould happen i never used to think it was a fuel problem but it is possible to only have fuel problems once engine is warm ?
Old Jan 8, 2016 | 03:54 PM
  #54
Yes the white filter going from the fuel pump to the carb inlet. Possible could be your problem all along.. Only way to tell is to flush the tank and replace the filter. Again process of elimination.. If in doubt on the fuel pump replace it as cheap as they are. Fuel Pump for Polaris Sportsman 400 500 600 Magnum 325 Outlaw 450 Predator ATV | eBay Getting old can't remember if you already have or not.. Early dementia..
Old Jan 8, 2016 | 10:19 PM
  #55
scram5050's Avatar
ok thanks for info sounds perfect
just one more question to bother you with lol ...
could my atv be over charging beacuse if youremember i told you a long time ago my regulator had melted wires (wich i fixed) could it stil be damaged though i hear regulators if there going bad can cuase the bogg and backfire problem i have ... when atv is idle i put my mmultimeter to the battery and it jumps all over the place from 14 to as high as 17 sometimes i heard its not suposed to go over 14.8
Old Jan 9, 2016 | 08:27 AM
  #56
Thought you replaced the regulator! Again fix one thing at a time.. Get a new one..
Old Jan 9, 2016 | 04:36 PM
  #57
scram5050's Avatar
no i never replaced it just cut the melted wires and put new bullet connecters on it but im guessing its still fried it cuz it shouldent be at 16-18 volts when revving engine
Old Jan 9, 2016 | 05:30 PM
  #58
NO it shouldn't be charging this much.
Old Jan 21, 2016 | 11:45 PM
  #59
scram5050's Avatar
can you recomend a cheap fuel pump that ships to canada all i have seen on ebay is oem pumps the one fuel pump u showed me before dosent ship to canada im not very good at finding parts lol
WILL THIS PUMP FIT A 2000 ? IT SAYS IT FITS SCRAMBLER 500 2010 BUT DOSE IT MATTER ? Fuel Pump FIT Polaris Scrambler 500 2010 Xpedition 325 2000 2002 425 2000 2002 | eBay
Old Jan 22, 2016 | 08:38 AM
  #60
Yes,these style fuel pumps will fit ALL Polaris models and mount right up in stock position. Just be sure you need one. Can't remember all that you've done,but pull the fuel line from the carb and spin the engine over. Should be a steady or pulsing stream of fuel. If it's weak,order a new one.
