scrambler bogg
#71
Why? Why not fix the problem. Toggling never really cools water cooled machines right,plus if you have one running constantly you're just burn out the fan motor quicker.Usually it's the sensor that shorts out at the top of the radiator that kicks the fan on and off that shorts out. Looks like this expensive one for 54 bucks.1998 2000 2001 Polaris Scrambler 500 2x4 Thermal Switch Sensor | eBay You can take your old one and match it up at most auto stores for at least half this price or maybe even less.
#72
All you do on testing the fan is just jump the wires to a battery OR in your case all you have to do is use a pair of needle nose pliers and jump the two spade connector lugs on the radiator sensor. Just slide the two wires back a little so you can get good contact. The fan should kick on when the key switch is on.
#73
All you do on testing the fan is just jump the wires to a battery OR in your case all you have to do is use a pair of needle nose pliers and jump the two spade connectors on the radiator sensor. Just slide the two wires back a little so you can get good contact. The fan should kick on when the key switch is on.
#74
Man I would at least buy a cheap Fram filter at Walmart if there is one close. Don't mix clean oil with dirty oil. Plus several different brands you can use. POLARIS 3084963 - Alternative oil filters
#75
ok do you have a link for the peice that gose on the filter or can i hand un tighten it and also do i need a tourq wrench ? lol everything is always so complicated with machines now a days ... i might have to find a freind just to do a simple oil change
#77
also with the fram filter is there a certain size or anything ?
#79
ok and i can loosen and tighten the filters by hand ? im not sure how tourqed they are lol
#80
May be on tight as they do just like car filters and tighten up over time. If a strong pair of hands can't loosen it, may have to use a filter strap tool or filter wrench.
