Need help
Old Apr 17, 2016 | 07:57 PM
RticKwad's Avatar
Runs Stealth!
Default Need help
After unloading in dark my new 570 we noticed smoke coming from the front somewhere. No smells of gas or antifreeze, no leaks I could see on my new trailer, no indicator on dash of hot temperature or service Wrench Icon. ATV ran okay, sounds okay. Turned off ATV then seem like smoke emitting from under plastic. Pulled the seat for visable inspection, noticed smoke trail from small weld on exhaust shield on right side mid section. Smell was slight maybe plastic or some fluid. Not rubber and couldn't identify any plastic or other material being touched or burned.
Any ideas.
Thanks,
R'
Old Apr 17, 2016 | 08:02 PM
Hope it's just exhaust paint buring.. Surely they have the extra exhaust shielding,fenders and seat foil by now that some early models had problems with from hot exhausts.
Old Apr 17, 2016 | 08:27 PM
RticKwad's Avatar
Runs Stealth!
What do you recommend OPT?
Should i start it and let run? I checked the inner bodycplastic no sign of melting. Something between, under or inside the exhaust pipe or shield?
Old Apr 17, 2016 | 09:03 PM
If the seat area,inner fender or cab area isn't getting hot,I'd drive it around and hopefully it's just the exhaust pipe smoking.They had enough problems on the first 570 models. I've had new ones smoke for awhile when burning off paint,oily spots from the factory,etc,but this usually went away after a good breaking in. I'd keep a good look out and if any problems show up,contact the dealer pronto.Hopefully it wont come down to that.
Old Apr 17, 2016 | 09:14 PM
RticKwad's Avatar
Runs Stealth!
Okay very cool, thanks OPT for the great tips!
Old Apr 20, 2016 | 03:44 PM
RticKwad's Avatar
Runs Stealth!
OPT, I talked with my dealer today was on the phone with an order switched me to service. Exactly what you said is what they told me. Other than this he mentioned look around to see if any VENT lines are disconnected. He admitted sometimes 1st factory occassional issue with a few disconnected VENT lines. I'll take a gander at those too.
Thanks,
R'
Old Apr 25, 2016 | 06:31 AM
RticKwad's Avatar
Runs Stealth!
Thanks,
R'
Well I ran my 570 idle for a while spent time moving it around and tinkering. No smoke or smells to report. Very strange! Hopefully what was baked on the exhaust from factory is now burned off.
Thanks for all the help!
R'
Old Apr 25, 2016 | 09:18 AM
R'
Don't know how many calls I got from people over the years about this same thing on some that would smoke or have strange smells. They just don't test run them long enough at the factory and neither do dealers when setting up new machines to break them in,burn off any oil residue,etc. Causes some people to panic who I don't blame after spending good $ on these things..
Mekronid
Apr 24, 2016 09:08 AM
Apr 22, 2016 01:05 PM
gadawg31
Apr 18, 2016 01:33 PM
misterddd
1) Engine problems..
Apr 15, 2016 10:25 AM
gomer4877
Apr 13, 2016 09:25 AM
