250 polaris xplorer 4 wd doesnt work after riding a while
Old 11-11-2018, 01:46 PM
mark jones's Avatar
Default 250 polaris xplorer 4 wd doesnt work after riding a while
my 2000....250 xplorer 4wd doesnt work in 4wd after a hour or so of snow plowing.....when i come out the next day it works again for a while and then it quits again...i just put a new battery in it last week to b sure that wasnt it....any ideas???
Old 11-12-2018, 02:41 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
have you changed the hub fluid lately? most likely it needs to be serviced or maybe even the armature plates are getting bad but I would start by cleaning and putting new fluid in the hubs. make sure to only put the correct Polaris fluid made for it as well.
Old 11-12-2018, 03:16 PM
mark jones's Avatar
Default 250 xplorer.....
i just replaced all front end....tie rods,ball joints axles,seals ,bearings with new fluid.....if i swap the battery with a fully charged one when it quits working it works again for about another hour or so.....it was doing this before i did all the work....
Old 11-12-2018, 06:38 PM
94harley's Avatar
Sounds to me like your charging system isnt working. The AWD works off a electronic coil, causing magnetism on the armature plate to engage the AWD. If your charging system isnt working, it will lose voltage in the battery, then the coils and no more AWD.
Old 11-13-2018, 03:36 PM
mark jones's Avatar
kinda what i was thinking....stator ?????...i have a new regulator im going to put in...it was cheap part...just to rule it out....i know doing the stator is a big job....wish i had done it when i had the starter out replacing it
Old 11-13-2018, 11:59 PM
94harley's Avatar
its not that bad on that machine to change a stator. Flywheel puller is the biggest obstacle. Install your regulator and check voltage at the battery. Should be around 13.5 to 14.5, give or take. If that isn't present, reply back and well see about diag on the system.
Old 11-30-2018, 03:35 PM
mark jones's Avatar
is it possible to pull flywheel and change stator without removing starter and bendix ?? just remove recoil housing and i can pull flywhee l?? im pretty sure thats it...machine old...lots of miles on it....like to replace it just to b sure its not a problem when im out in middle of nowhere stuck in a mudhole with no 4wd....thanks
Old 11-30-2018, 11:00 PM
94harley's Avatar
Yes
Jeff Sims
09-14-2018 09:06 PM
old_blew_72
08-31-2018 07:35 PM
Sparky12.
04-13-2017 02:20 AM
Honda321
10-02-2016 11:47 AM
connexion2005
07-20-2016 09:24 AM
Quick Reply: 250 polaris xplorer 4 wd doesnt work after riding a while
