Understanding the Polaris 4wd system...
Old Feb 10, 2011 | 09:51 AM
  #31
Deek901's Avatar
Originally Posted by ArticZap
The front diff is locked all the time. When the back wheels slip 1/5 of a turn, it tells the comp to engage the front hubs which enables all 4 wheels to spin. Once traction is regained the front hubs disengaged. Hope this is right and helps.[img]i/expressions/face-icon-small-wink.gif[/img]
I am a newbie. Do most folks just do trail riding with the Polaris switch in the "4X4" position? So that when they need awd activated it happens as you describe? Or do folks ride around in "2x4" (with the thought to save fuel), then switch into "4x4" when they think they'll need it.
I also questions on the "4x4 ADC" mode, but will hold off on that for now.....
Deek
2011 Polaris Sportsman Touring 550 EPS
Old Feb 10, 2011 | 10:00 AM
  #32
Deek901's Avatar
Originally Posted by fourlix
... But for rock climbing, and technical, slick hard surfaces, or downhill, it only lets the front wheels pull when they are slower than the rear. And sometimes that is too late.. Instead of a steady, even pull, the Polaris system works with the slowest common denominator. If a wheel needs a little extra pull and speed, like an outside wheel, the Polaris system will not deliver, but merely let the wheel "ratchet" ahead of the mean average speed supplied by the one speed driveshaft system. Instead of a more sophisticated system which would "differentiate" speed and power requirements of each wheel....
This is starting to make sense. Are you familiar with Polaris' "Active Descent Control" works? I asked the dealer, but I'm still confused how that works, or when to use it. He also said they (dealer) could set the ADC to work one or two ways, which I have forgotten already....<g> I don't have the ATV yet, nor have I ever used one before, so please excuse my ignorance.
Deek
2011 Polaris Sportsman 550 Touring EPS
Old Feb 11, 2011 | 10:19 AM
  #33
TLC's Avatar
TLC
Deek
The ATV goes in and out of AWD on its own, reason being if the Polaris true 4wd never kicked out and remaines in AWD the ATV would be unsteerable, it would be like having diff lockers engaged full time. Polaris does not have a 3x4 limited slip (Normal 4wd) option to allow for easy steering, its 2wd or AWD only.
I only used 2wd mode for those days I like to power slide the rear end around turns on the trail.
Old Feb 11, 2011 | 10:29 AM
  #34
JCDEYO25's Avatar
My switch has been in AWD for years....For my driving it's perfect....
John
Old Feb 12, 2011 | 08:07 AM
  #35
Deek901's Avatar
Thanks for the replies, guys. I'm learning slowly but steadily! I hope to take delivery of my ATV around 24 Feb.
Deek
2011 Polaris Sportsman 550 Touring 550 EPS
Ramman1
Aug 11, 2022 01:53 PM
ghost civic
Jul 30, 2015 04:09 PM
chris7420
Jul 30, 2015 02:04 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
