broke front chains
Old Nov 23, 2001 | 07:18 PM
ftwflh's Avatar
I got my 96 400 sportsman hung up good on a sand bar in river mud and sand and when i was pulling it out with my 425 magnum i ended up breaking both front 4x4 chains.Has anyone else had this problem and how do i cure it other than staying out of sand) Brad ----------------96 425 magnum 4x4-------------96 400 sportsman------------2001 Breeze (my sons)
Old Nov 23, 2001 | 07:58 PM
fast4wdkid's Avatar
yes its happened to me several times... never pull with your machine in reverse. this makes the frt end get great traction an will snap the chain. it will always happen if you engage the 4wd while the rear tires are spinning. the 99s and up have sensor that will not allow the 4wd to engage if the rear tires are spinning over 15 mph
Old Nov 23, 2001 | 09:16 PM
ftwflh's Avatar
now that you said that all 3 times i have broke them i was either pulling or being pulled in reverse.THANKS
Old Nov 24, 2001 | 10:43 AM
kukerdan's Avatar
wait a minute, if im rolling real slow, lets say 10 mph and throttle off on my scramby, can i hit the awd button?
Old Nov 24, 2001 | 06:20 PM
ftwflh's Avatar
kukerdan you can hit the button any time as long as your rear wheels arent spining.I fixed both chains today and all i needed was a new master link on the sportsman and to take a link out of the magnum.I got off cheep this time.
Old Nov 24, 2001 | 08:12 PM
kukerdan's Avatar
ok i never hit it when its moving anyway,
but i had a crazy idea
i have lake front property and love the ice, lets say i go flying in 2wd, slam the brakes, of course the quad will keep sliding, then engage awd and have traction, that would work right? or while sliding stop tires and put it in reverse or neutral
Old Nov 24, 2001 | 08:22 PM
ftwflh's Avatar
when you try it let me know what happens.sounds scary to me.
Old Nov 24, 2001 | 08:45 PM
Campy's Avatar
lol kukerdan, you might wanna be careful with it. But I'd say that just as long as your tires are all moving the same speed, it's fine to engage 4wd. As for shifting while moving, just make sure your drive tires are completely locked up, and don't let them unlock until you've got enough engine speed to overcome the fact that they're going the wrong way...
Also, I'd be pretty careful if I were you, and I'd say not to try anything at too high a speed, or you're likely to damage SOMETHING, whether it be tires, driveline, or you.
Old Nov 24, 2001 | 10:29 PM
kukerdan's Avatar
thanks i wont, ill get my freind on his kawi to test it first [img]i/expressions/face-icon-small-happy.gif[/img] jk
Old Nov 25, 2001 | 10:16 AM
Campy's Avatar
LOL! Good idea!
greg74
Sep 10, 2019 03:03 PM
mdrkcckv
Jul 22, 2015 09:10 AM
Peter_
Jul 18, 2015 07:06 AM
95wolv
Jul 17, 2015 08:13 PM
jettman
Jul 6, 2015 12:16 PM
