Belt Deflection
Old May 4, 2003 | 12:28 PM
SageCrusher's Avatar
Default Belt Deflection
Have a 95 xplorer
Belt deflection is way off, installed new belt, shimmed the primary side clearance, and shimmed the secondary clutch as high as I dare go. Still need to ge the belt tighter.
Is there any movement to be had in the motor, as in snowmobiles that is where the adjustment is made.
I realize that the clutches will have to be re-aligned, but how is the belt deflection adjusted on the ATV????
Old May 4, 2003 | 12:43 PM
NCScrambler's Avatar
Yes, see this post and check your PM.
Old May 4, 2003 | 01:59 PM
NC Check your PM.. as that posting doesn't help, as I'm in alignment....
Going to check my CTC and see how far off it is......Never liked the Idea of having to Shim motor mounts, I need to move forward with the motor not side to side..
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
hueby
Nov 6, 2015 11:34 AM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
