Pulse and lag at WOT.
I received a 100cc quad because previous owner couldn't get it to run. No ideas of brand or specifics.
I replaced all warn and damaged components, as well as the carb. This includes the battery, starter, ignition coil and relay. Fired right up and ran very well. Even under my weight (260lbs) it would easily do wheelies. Could hit 30mph on the road. My small son ran it with the limiter on for weeks without issue. Was more reliable than a new quad we bought.
about a month ago it started popping and backfiring at the limited WOT. I was able to smooth it out by adding a small amount of choke.
Recently, reliablity has dropped. Now it will run ok, still popping and sluggish.
I bought new jets for it as well as checked valve lash. Intake was about a full turn in.
wlWith no limiter and WOT, the RPMs are very unstable and it will buck enough to nearly throw me.
It idles well and even. Low to mid throttle is snappy and even. Mid to high gets a little sluggish.
I have increased the main jet to a 90, than to a 96 currently. The 96 is less stable than the 90.
My current reading indicates not enough fuel, but increasing size has made it less stable. As well as I only have one jet larger. Am I missing something? I have pulled and checked the carb each time I have adjusted the carb. Needle is 4th highest setting.
Clean carb out and put jet back to standard, check fuel flow from tank. Fit a new plug and try bike. If it still isn't running right, check exhaust for loose baffles etc. If that is OK, you mentioned having to turn inlet valve adjuster a full turn. Either previous owner got the lash badly wrong or something has worn in the valve mechanism, I would try a new coil and CDI first, but it could be a valve problem, which would require a top end strip and check of all components.
The original owner was not mechanically inclined and anything more than a battery change would be out of the question. lol. So I assume intake valve lash was from wear. I adjusted the valve before changing the jet. It was not loose on inspection, so it was either set that way or wear. The jet was more of a last resort. I checked compression and it is about 90psi.
The CDI that came with the kit i bought may not be correct for this quad. I installed it and even the idle was uneven. It was jerky all through the throttle range.
I have worked to reduce all rattling and have played with the muffler a bit. There is nothing that sounds loose or off there. It is not excessively loud either. Similar in volume and tone to the new quad we have.
I will pull the carb again and blow it out again just to verify. While inside, I will drop the jet a few sizes. I am not sure what the original was size-wise. It does not have a number on it and I cant locate documentation. I have seen in other forums/site that carbs on similar quads seem to be around 65. 90 and 96 both have the same problem and 96 is the worst of the two. So I think I will try about 75.
A worn cam would restrict the amount of air/fuel mix getting into the cylinder, trouble is adjustment is for wear on the rocker, so you can't tell if the cam is worn without removing and measuring it. I would put the old coil back on and try it, try another CDI and, if you don't get an improvement, take the top end apart, may be worth checking rings and bore for wear too, 90psi is on the low side of acceptable. Can't see altering jets being the answer, if it once ran right on that original main, it should still do so.
