z250 help! go faster
thank you, what kind of filter should i get cause i know k an n is good but it i dont think they got one for the 250, whats the best slip on for the z? and one last question dont you only get a jet kit after you get a pipe, cause thats when you would rejet right? thanks
tom
tom
I don't know what the best slip on for a z250 is and yes you do only get a jet kit after you pipe it but you should get all those at once. You can check rockymountain atv
Go with the Twin Air filter. There is a z250 rider on these forums some where that has Twin Air filter. As for slip ons, I would go with the White Brothers E-series because it has adjustable discs in it so you can adjust noise, or if you want the power to hit at the bottom, mid, or top. Or I would go with the Yoshimura Compitition silencer. If you want a full system go with the DMC Alien.
