starter going backwards?
Old Jul 17, 2004 | 05:56 AM
lee844's Avatar
Default starter going backwards?
have a 90 quadrunner 4wd 250,my starter seems to turn wrong and turn when i pull star pls help?just did engine overhaul!!!!pls help me!!
Old Jul 17, 2004 | 10:50 AM
MBrooks420's Avatar
If the starter is turning over with the motor the bendix is stuck. You may be able to get it loose, by taking it apart. Why do you think it's turning backwards? Is the starter hooked up correctly? If so I can't think of a reason of why it would turn backwards. What did you replace in the motor?
Old Jul 17, 2004 | 01:36 PM
lee844's Avatar
WHEN I PULL THE PULLCORD WITH THE STARTER OUYT IT TURNS THE OPPOSITE WAY INSIDE THE GEAR WHERE THE STARTER MOUNTS, I COULD HAVE AQ WIR BACKWARDS SOMEWHERE,I DID COMPLETE ENGINE OVERHAUL ALLL THE WAY THROUGH
BUT EVERTHING WAS DONE BY THE BOOK, I HOOK THE STARTER UP WITH JUMPERCABLES WITH HOT WHERE GROUND SHOULD BE ,,(OUT OF ENGINE FIRST) AND TYHE GROUND THE THE POST ONT THE TOP OF THE STARTER IT GOES CORRECTLY,,,DO U KNOW WHERE I CAN GET DIAGRAM FOR THE STARTER AND ELECT
OH, BTW WITHH THE STARTER HOOKD UP IT JUST TURNS FREE WITHOUT TURNING ENGINE JUST SPINS STARTER
Old Jul 17, 2004 | 02:12 PM
lee844's Avatar
NO BENDIX ON THIS STARTER
Old Jul 17, 2004 | 02:59 PM
lee844's Avatar
WICH WAY SHOULD THE STARTER GEAR TURN?
MIGHT HAVE FOUND PROBLEM , THINK THE GEARS INSIDE THE MOTOR,CLUCH GEAR WAS PUT I N UPSIDE DOWN ,,,MAYBE LET U KNOW LATER TODAY..THANKS FOR THE HELP I MAY NEED U LATER THOUGH,,,LOL
Old Jul 17, 2004 | 03:01 PM
MBrooks420's Avatar
This forum like most, frowns upon ALL CAPS. Is the starter rope wound the wrong way? Even if it were I don't see how the pawls could engage the recoil cup correctly. Your manual doesn't have any schematics? If not I'd recommend looking for a used factoy manual on e bay.
Old Jul 17, 2004 | 03:37 PM
lee844's Avatar
I HAVE MANUAL GOING TO CHECK THE CLUTCH GEAR FOR STARTER
Old Jul 17, 2004 | 03:38 PM
lee844's Avatar
sry for the caps didnt even notice,lol
Old Jul 18, 2004 | 08:20 PM
lee844's Avatar
Found the problem, the starter clutch was in backwards. Thanks for the help
Johnny Mac
Aug 15, 2019 03:13 PM
badgerboy1
Sep 26, 2017 06:11 PM
wrencher82
Sep 28, 2015 10:02 PM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
