Reccomendation For New King Quad 700 Tires.
I have a new 04 King Quad 700 and am not happy with the stock tires, but am not sure what to replace them with. I do most of my riding on old logging roads and hard packed dirt trails in northern california. Not much mud at all. Can anyone recommend a good tire? Id prefer a radial tire if possible but will consider a bias ply as well. Thanks.
Originally posted by: suprdavtn
read my sig.
read my sig.
did you need spacers for the c6 rims and are they wider than stock?
also, is 26 the equivelant of the stock tire or a inch bigger?
Thanks.
Your stock tires say they are 25's but if you actually measure them they are about 23-24's depending on air pressure. When i measured my mudlites, they are about 25.5's. There is no spacer needed for these tires... I am just assuming he didnt like them.......you might feel the same way too. I liked them... thought they were pretty good. Just look around for tires that will suite your needs. The 26's will give you a little more groud clearance.
When looking, check the weights as well. Even though you have a 700, you will notice a heavier tire. The Bighorns for instance are a very good durable tire. They are however very heavy and will cause loss of acceleration. It's all in what you want though, what is most important to you. Of all the ones mentioned, the Carlisles are the lightest, the Bighorns the heaviest.
