LTZ250 Choke
Old Feb 21, 2005 | 02:44 PM
Rottweiler's Avatar
Default LTZ250 Choke
Since day one my 04 LTZ250 has had to be manually chocked for 5-10 minutes or it will die on me. I assume it 's an adjustment that is needed but I have yet to mess with anything mechanical on it. Can anyone shed some light on my next move?
Thanks,
Chuck
Old Feb 21, 2005 | 03:07 PM
hondabuster's Avatar
The idle circuit is too lean to take over when the motor is still cold. Try going 1/4 to 1/2 turn richer (out), on the mixture screw, this only effects the idle circuit.
Old Feb 21, 2005 | 03:15 PM
Rottweiler's Avatar
Thanks for the quick response!!! I will try it out tonight if I can find where the screw is....lol
Old Feb 21, 2005 | 03:24 PM
alba
Its #27 is this view, itll be under this cap #23.
Old Feb 21, 2005 | 04:10 PM
Rottweiler's Avatar
Wow, what service!!! thanks so much [img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 21, 2005 | 04:52 PM
Hey, no problem.
Just remember, when the temperature and humidity go up this summer, it might be a bit rich at idle, and youll want to turn it back in, that 1/4 to 1/2 turn. Heres a site, with symptoms of rich and lean, so you can keep an eye on that.
jetting
Old Feb 21, 2005 | 04:55 PM
Rottweiler's Avatar
thanks!!
Old Feb 21, 2005 | 05:00 PM
BrocksZ's Avatar
Also, you have to drill out that little brass cap that covers the mixture screw. Its all the way on the bottom of the carb. towards the front (closest to the motor). You may have to loosen the intake boots and turn the carb to the side a little bit. Its easiest to work from the side withOUT the exhaust on it. Hope this helps.
Beeline08
Nov 11, 2016 04:00 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
