LT 80 Starter RELAY
Old May 23, 2005 | 03:58 PM
ZIXXER's Avatar
Default LT 80 Starter RELAY
HELLO new to this site. I have a 2000 lt 80 for my son and I'm having a problem getting the starter to engage. I just replaced the battery and the starter will not engage. I looked at the starter relay and it is making a clicking noise. Is this normal? Would anybody know what I should check with the multimeter to see if Im getting juice. I did have problems in the past getting it started and had to jump the battery. any info would be great.
Old May 28, 2005 | 06:37 PM
CJ1234's Avatar
i WOULD ALSO LIKE TO KNOW THE ANSWER TO THAT BECAUSE I AM EXPERIENCING THE exact SAME PROBLEM TO THE TEE.....I WAS TOLD EITHER THE STARTER OR RELAY[EVEN THOUGH ITS CLICKING] AND ALSO IVE ELIMINATED THE POSSIBILITY OF THE EMERGENCY BRAKE SWITCH,AS I GET NO CLICKING WHEN THE BRAKE IS OFF SO I KNOW THAT ITS WORKING PLEASE HELP/!!!!!!!!!!!!!!!!!!!!!!!
Old May 31, 2005 | 09:50 AM
ZIXXER's Avatar
I jumped the starter by pulling off the hot lead and using a spare battery to give it power and the starter worked fine. you might want to try this first. Going to purchase the relay today. Will let you Know if this was the problem. By the way my relay was making the same clicking noise. Let me know what you find .out .
Old May 31, 2005 | 05:34 PM
CJ1234's Avatar
Ok thanks..
Old Jun 1, 2005 | 08:56 AM
ZIXXER's Avatar
ALso try to jump the solenoid by the starter with a screw driver. If it engages then it probly is the relay. Roughly about $20 to $30.00 from suzuki.
Old Jun 1, 2005 | 03:43 PM
CJ1234's Avatar
allright thanks..
Old Jun 26, 2005 | 11:37 PM
CJ1234's Avatar
I figured out that it was the starter..
Old Jul 3, 2005 | 02:00 PM
Instygatr's Avatar
i have a 99 lt80 and it did the same thing. i found a circuit breaker under the right rear fender. it just needed reset. i pushed in the reset button and everythin works just fine.
Johnny Mac
Aug 15, 2019 03:13 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 28, 2015 10:02 PM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
