can't get jet kit tuned in on my Ozark
Here's my quad and my current mods...........
2005 Suzuki Ozark 250
Twin Air Filter
DynoJet stage 2 Jet kit
spark arrestor removed(reinstalled when riding in dry areas)
a good break in was done on the motor(drive it like you stole it after it warmed up)
Now, the recomended jet per my altitude and mods was installed and the settings were set to the jet kit's recomendations accept for the air/fuel adjustment screw cause there's a plate covering where the screw adjustment would be. I took it out and could barely go at all. Brought it back and checked the spark plug only to find it showing real lean. So I go one jet bigger(132). Took it back out and it was MUCH better. I brought it back and checked the plug again only to find that it was still lean, so I went one jet bigger again. This time though, it was spitting black smoke when trying to start off, so I went back to the 132 jet and went one notch richer on the needle. I then took it out and rode for a bit. Mid range was not as strong, but top end was much better. I brought it back in and checked out the plug only to find it running a bit on the rich side.
I've been riding with it like this for a couple of months now, but I've been having to replace the spark plug about once every 2-3 weekends of riding cause it gets fouled out. Is there any way I can take that metal plate off of where the air/fuel adjustment should be so I can adjust it to where it needs to be? Is there something else I can do to remedy this problem? I've been thinking about just getting a Pro Circuit pipe for it to lean it out a bit, but I don't think that will fix my problem, but only compound it.
As it sits right now, the quad has a really nice top end pull and I can easily hit the rev limiter in 5th gear. I also had to decrease the plug gap from 0.028 down to 0.025 cause it was blowing out the spark. But even so, I'm able to easily pull on my friend's 4 stroke Polaris 330 cc and 2 stroke 250 cc quads so the power is there, it's just the low end is not as good as what it used to be and it's still running a bit rich.
Twin Air Filter
The cap over the mixture screw on my 03 was made of plastic and i could flick it off with a fingernail. Maybe in other ares they are metal. If it is, just take a small drill, and start a hole in it, but dont go very far. Then take a sheetmetal screw, and thread it in, then pry the little cover off with the screw.
If you are looking at the carb from the driver's side of the quad, look on the lower left hand part of the carb. You will see a flat brass like round area with a hole in the center of it. You need to take this plug out in order to adjust the air/fuel ratio screw, but be forewarned. The screw only adjusts idle and low throttle air/fuel ratio. The needle setting adjusts your midrange air/fuel ratio, and the jet size determins your top end air/fuel ratio. Now that seems easy enough, but when you change jet sizes, you typically need to also change the other two settings to keep everything running right.
Elkaholic
09-06-2015 02:44 PM
