LT250R Please Help!!!
Old Nov 7, 2005 | 11:17 PM
lt250RaCeR88's Avatar
Default LT250R Please Help!!!
My lt250r doesnt have spark it isnt the stator or the ignition coil i have power coming out of the stator going into the cd but no power comming out of the cdi to the ignition coild. The blue, blackandred, blackandyellow, blackandwhite are all the wires connecting the cdi and the stator and the black wire comming out of the CDI is the return power wire to the igniton coil to give it spark that wire has no returning power. Any suggestions... CDI DEF BAD OR WHAT we are turning the switch on and kicking it over to get power!!
Old Nov 8, 2005 | 05:13 PM
? Anyone ?
Old Nov 8, 2005 | 10:28 PM
sblt500r's Avatar
theres no way to test a cdi. it either works or it doesn't. might be your coil. check the plug cap. and make sure all of your connectons are clean. its rare that a cdi will fail, most always its something else thats wrong.
Old Nov 8, 2005 | 11:14 PM
Of course you can check your cdi all the wires that run from the stator or magneto to the cdi are all receiving power bu the black is the returning power which goes to the igniton coil! What you do is get a DVM and test the voltage when the swtich is on and is kicking over! I Get plenty voltage to it none coming out going to the ignition coil to make it fire!
Old Nov 8, 2005 | 11:41 PM
sblt500r's Avatar
so why are you even asking anything? seems like you know its the cdi so why ask this question?
Old Nov 9, 2005 | 11:14 AM
Bubba297's Avatar
All of the manuals will tell you there is no way to check the CDI unit. Not all tests are done by checking voltages either. You must check resistance across certain areas. And I prefer a sweep analogue meter for checking these type of items.
Have you ever thought that if you grounded the kill wire that you would still have power everywhere but to the coil? Sorry, but your trying to diagnose wrong. You need a service manual to check things correctly.
Old Nov 10, 2005 | 12:32 AM
mgrotel's Avatar
i had no spark a while back but it was a wire under the seat, i think yellow with an orange stripe if i remember correctly
Old Nov 10, 2005 | 08:11 AM
i figured it out thanks alot for the replies the kill switch had a short in it causeing all power to fail thanks!
Old Nov 13, 2005 | 10:14 PM
Sparky8370's Avatar
Guess he was right. Glad you found the problem.
Levi Enstad
Sep 26, 2015 08:00 AM
Halffast17
Sep 11, 2015 02:30 PM
LTqracer
Sport Quads
19
Jun 2, 2004 07:20 PM
donpeter
Apr 4, 2001 12:31 AM
Steve10
Aug 2, 2000 03:32 PM
