Eiger- erratic throttle
Old Mar 13, 2006 | 12:17 AM
nick05eiger's Avatar
Default Eiger- erratic throttle
Allright, thanks, I'll give that a shot next time. sure beats pullin off the entire rear plastics, gas tank, tank cover, rack, airbox....and other stuff I can't even remember. Took 10x as long to tear it apart as it took to check the carb. All except for tryin to seat that stupid diaphragm. I found a little bit of petroleum jelly in the groove helps it stick though. You get yours back in the shop yet?
Old Mar 13, 2006 | 12:37 AM
Hemi4u2nv's Avatar
I wouldn't think you'd have to take all that off. Especially the rack, air box, and entire rear plastics. I can pull the carb all the way off after disconnecting the vacuum lines and the throttle cable by just taking the side panels off but maybe since yours is a manual shift,
there's linkages in the way? It's a little harder to put it back on if the tank and tank cover is on but its definately doable. If you don't have a service manual, you should get one. It has made things alot easier for the maintenance I've done to mine and it's only about $40.
My dad has it now and he's going to take it in later this week when he travels back home. Thanks for asking.
Pehter
Oct 3, 2024 11:00 PM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
