magura clutch
Guest
Posts: n/a
hey i found a magura hydraulic clutch for my z250 on ebay for $60! from what ive heard of other people, theyre a really good buy, but if it goes on my left handle bar, how will i have a park brake, or will i just have to use a twist tie around my frontbrake or something like that, anybody else that has the clutch, could u help me out?
Is the hydraulic clutch for your quad I have one on my ds650 but my parking brake is on the right side what I would suggest is if you don;t want to use the parking brake get a parking brake block off plate instead of making it look bad by rigging it make sure your use the right fluid if there isn't much in the clutch and before you connect the slave cyclinder or even take the old clutch off mark out where the arm is for the clutch when engage and disengaged then take the old and on with the new and make sure it is engaging if it isn't engaging the clutch you may either need to bleed the hydraulic clutch like brakes or it isn't pulling enough so be careful
cdstang
Aug 31, 2015 07:52 AM
