Ltz 400 will only push start
Old May 29, 2018 | 02:20 AM
  #21
You don't say how long since you set the valves. Check for a spark, and check compression again, if there is no spark, you have the dreaded "only sparks when I take my finger off the button" problem, no known cure. If compression is down, re-set the valves.
Old May 29, 2018 | 05:05 AM
  #22
Blacsta's Avatar
it’s been about 2 weeks ago. With maybe 4-5 hours of riding time before the problem started again. And what the dreaded only sparks when I take my finger of the button??
Old May 30, 2018 | 01:06 AM
  #23
"only sparks when I take my finger off the button?"
Exactly what it says, you take the plug out, re-fit the cap and spin the engine over on the starter to check for a spark, and:- it only sparks when you take your finger off the button.
If the valve has closed up again, sounds like a problem, and it may be best to take the head off and check why it is doing so. Loose valve seat? Stretching valve?
Old Dec 16, 2018 | 03:22 PM
  #24
shannonleigh1011@hotmail.com's Avatar
Default hi mucky could you help me with my quad pls
Originally Posted by ltz400bigbore
yea i got a ltz 400 and it sat for like 2 mouths and i got it out and electric stater will not fire it up i went out got new battery and spark plug but if i push start it it fires right up with no problem and runs good and after your drive it for 10 min and stall it elctric starter will fire it up i clean carb out and every thing what else should i do help plz
Originally Posted by mucky
check your fuel petcock in the tank, it only works with a vacuum from the carb, turn it to prime and see if it will start then, or you could still have a dirty carb. plugged jet, defective fuel needle valve or like what was said before stuck valve or misadjusted valves
it’s a ltz 400 it’s just had engine rebuild run in for about 8 hours been out for 5 hours since just before I was about to come home it started to splutter I’ve cleaned the carb and it’s got Fresh petrol and the carbs filling fine it’s got a lovely spark just turns over then back fires what else could it be please ? Thanks John
Old Dec 18, 2018 | 07:53 AM
  #25
LT80's Avatar
LT80 Expert
Like mentioned in that old thread... maybe check the valve clearances.
Old Aug 4, 2022 | 10:20 PM
  #26
RyokaJay's Avatar
same thing happens to mine
2x_lung
1) Engine problems..
48
May 24, 2023 05:22 AM
BEEFKING69
Jun 17, 2015 12:38 AM
jayking232003
Jun 9, 2015 02:54 PM
clsharky
Jun 8, 2015 11:38 AM
1000gade
May 27, 2015 12:37 PM
