ltz50 quad no power
Old Nov 28, 2007 | 11:23 PM
  #331
tbirdsc50's Avatar
Default ltz50 quad no power
lol when the cdi , K&N ,comes in i might put on ,when he is in school to check it out , then ive it for x-mas, i look for graphics could not find , if u find some let me know ,
x-mas shoping, ,i dont know what to buy a boy who has as 4 wheller, lol
Old Nov 28, 2007 | 11:39 PM
  #332
dmontzsta's Avatar
I would really like to ride a LTZ50 with CDI, Pipe, K&N/Jetting, 3 Rollers Removed. I wonder if it is a big difference over stock?
Old Nov 28, 2007 | 11:44 PM
  #333
tbirdsc50's Avatar
just drilled exhaust, 3 rollers and spacer , is a big difference, air filter and cdi , will be BIG
Old Nov 28, 2007 | 11:55 PM
  #334
RIDE!'s Avatar
Hello everyone......new to the site too, but reading these threads and working on the little 50 since July. Last night I decided to cut the exhaust in two and remove the entire baffle, had the pipe rewelded, painted it, man.....BIG difference in torque. Won't be buying a pipe anytime soon, but I'm sure FMF or CT still out performs it.
Old Nov 29, 2007 | 12:05 AM
  #335
EdKatt's Avatar
Man you went big! Cut that sucker in half! You should get that k&n filter too. Im waiting for tbird's opinion on the cdi to order it.
Old Nov 29, 2007 | 12:10 AM
  #336
dmontzsta's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: EdKatt
Man you went big! Cut that sucker in half! You should get that k&n filter too. Im waiting for tbird's opinion on the cdi to order it.</end quote></div>
Is he testing both CDIs?
Old Nov 29, 2007 | 12:14 AM
  #337
RIDE!'s Avatar
After taking "tlronny" idea, I too drilled a hole in the baffle, then bent the tube that's on the bottom of the baffle upward so the exhaust wouldn't hit the inside of the muffler. One thing led to another.....I had holes in the baffle, and bent marks where I tried knocking the spot welds off, I looked inside and said "No way". So then I went drastic.
I've put the K&N on, but it just fell flat on it's face when I opened it up. I stopped at every shop around here and nobody had that type of jet at a 76 or 82. I put the choke on, which made it better, but it's still not right, so I took the K&N off and put the stock back on for now.
Old Nov 29, 2007 | 12:26 AM
  #338
EdKatt's Avatar
I hope finding jets isn't a problem!
Old Nov 29, 2007 | 12:35 AM
  #339
RIDE!'s Avatar
It was for me. I was thinking about ordering a main jet for a 07 LTZ90, but I don't know what the jet size is. The stock 50 is a 58, but the diamameter is a little larger than say a main for a Raptor, but they're both Mikunis?
Old Nov 29, 2007 | 01:02 AM
  #340
tbirdsc50's Avatar
the cdi will be here , they say !! friday , will test sat will let you know , i dont remeber who , but some one talked about getting and changing the jets, will have to read back ,
