ltz50 quad no power
Old Jul 30, 2007 | 02:35 AM
  #81
edc7002's Avatar
Default ltz50 quad no power
when you are replying to a message click the little "picture frame icon" after <u>U</u> then just enter the URL: code or address
the image must be hosted on any free hosting website.... once you host the image Right Click the picture goto properties copy URL and just paste in the picture frame option
Haven't heard anything about a spocket
Old Jul 30, 2007 | 07:59 PM
  #82
daquadfather's Avatar
Can someonel please tell me the stock restrictions on the Z50 (I have just bought one and it didn't have the correct manual!!!).
Someone mentioned about the spacer? Is this in the carb?
There is virtually no bottom end power. After being used to the LT-A50, this is a big disappointment. I'm sure it will go faster than it presently does
Anything I need to do in the transmission or air box?
Any help greatly appreciated.
Old Jul 31, 2007 | 09:59 PM
  #83
KINGQUAD450's Avatar
Just installed the LTZ90 cdi box. It increased the wheel rpms from 300rpms to 550 rpms. Hauling my fat butt on flat ground it was about 18.4 mph (according to my gps) motor was still under a load going down a slight grade it was up to 24.3 mph withthe little guy on I thinkit will go a lot faster. So you can gear it down a good bit and still keep a decent speed. No increase in low end power not that I thought it would.But it is a start.
Old Jul 31, 2007 | 10:51 PM
  #84
Hibrass's Avatar
Kingquad450,
That is great news! I haven't had a chance to retest my boys 50 with the new LTZ90 CDI. I hope I get the same results! Oh and you can increase the low end grunt by lightening the clutch weights with no sprocket change... Give it a try you will be surprised!
Good Luck,
Hibrass
Old Aug 1, 2007 | 11:09 AM
  #85
How did you lighten the clutch weights? your talking the little roller that fall out when you remove the spacer from the drive right?
Old Aug 1, 2007 | 08:52 PM
  #86
Hibrass's Avatar
Yes those little rollers are the key to improved low end performance. Use a drill bit and remove and equel amount material from all of the rollers. ( Go in small steps.) I started by taking one then two rollers out of the clutch and testing to see how it worked. Once I decided the numbers of rollers (One in my case.) I measured its weight on the one roller and devided by six and experimented until I took that amount off each roller. Then reassembled the clutch. Seems to be working so far...
Old Aug 1, 2007 | 09:33 PM
  #87
<div class="FTQUOTE"><begin quote>Originally posted by: Hibrass
Yes those little rollers are the key to improved low end performance. Use a drill bit and remove and equel amount material from all of the rollers. ( Go in small steps.) I started by taking one then two rollers out of the clutch and testing to see how it worked. Once I decided the numbers of rollers (One in my case.) I measured its weight on the one roller and devided by six and experimented until I took that amount off each roller. Then reassembled the clutch. Seems to be working so far...</end quote></div>
do you remember what size you ended up at?
Old Aug 2, 2007 | 08:30 AM
  #88
Hibrass's Avatar
Sorry man,
It was a 1/4 inch bit and I drilled down about 3/8 of an inch... If I find my notes I will post the numbers. But a brief search as yielded nothing so far...
Hibrass
Old Aug 2, 2007 | 01:32 PM
  #89
edc7002's Avatar
1/4 bit with 3/8 depth into each roller
Or a 1/4 inch pilot and finished with a 3/8 of an inch all the way through
How many rollers are there, 6???
Old Aug 2, 2007 | 01:54 PM
  #90
DSengineer's Avatar
Has been here a long time!
<div class="FTQUOTE"><begin quote>Originally posted by: edc7002
The family
The baby when it was bone stock tryin to do some donuts
I'll posted more picz and a video when i get the jet kit</end quote></div>
Nice helmet you got on that kid...[img]i/expressions/face-icon-small-disgusted.gif[/img]
