ltz50 quad no power
Old Aug 2, 2007 | 09:27 PM
  #101
KINGQUAD450's Avatar
Default ltz50 quad no power
I ordered a 9 tooth front and a 43 tooth rear sprocket today switching it over to 420 chain we will have to wait and see what happens.(hopefully they can still get them)
Old Aug 3, 2007 | 09:47 PM
  #102
<div class="FTQUOTE"><begin quote>Originally posted by: Hibrass
I used a 1/4 inch bit and drill into the weight to a depth of about 3/8 on an inch... And there are 6 roller weights in the LTZ50 clutch. You may have to adjuct to suit your riders taste but it doesn't take that long about an hour all told...
Good Luck,
Hibrass</end quote></div>
Did your rollers already have a hole thru them? Took a look at them tonight and they have 15/64 hole all the way thru them. We took three rollers out all together made a big difference,so drilled them out to 19/64. Lost one of the dowels in the side cover so I need to make a new one
Old Aug 7, 2007 | 05:31 AM
  #103
AIRMOBILE101's Avatar
The rollers(variator weights) come in different weights(grams). My sons little Kfx50 came with 8g weights. I installed 6g weights and it definitely helped with the takeoff. Or, you can remove three of the weights and evenly space the other three weights for better takeoffs. Scooter websites offer a variator weights in different sizes and weights.
Old Aug 7, 2007 | 07:31 AM
  #104
I removed three of them yesterday to try why waiting on the new sprockets. The biggest problem now is I got it going so fast it needs to be turned way down for him to ride that is onlt running about 1/3 throttle if that
Old Aug 7, 2007 | 06:51 PM
  #105
DSengineer's Avatar
Has been here a long time!
<div class="FTQUOTE"><begin quote>Originally posted by: AIRMOBILE101
Scooter websites offer a variator weights in different sizes and weights.</end quote></div>
What is Scooter website? Link?
Old Aug 8, 2007 | 01:27 AM
  #106
edc7002's Avatar
i got as far as removing that first nut that was hard as hell then what ??? help
i couldn't remove anything else what else i have to do???
Any images
Old Aug 8, 2007 | 07:35 AM
  #107
you are on the wrong side of the motor to remove the rollers
Old Aug 8, 2007 | 12:36 PM
  #108
DSengineer's Avatar
Doh! You might want to take it to the dealer
Old Aug 8, 2007 | 01:15 PM
  #109
they tell you show to do it in the owners manual if that help.
Old Aug 8, 2007 | 02:42 PM
  #110
edc7002's Avatar
I knew something was up when i didn't see any oil lol
I'll attempt it again tonight. I will post more images when
I'm done for anyone else like myself.
It's my first quad guys, go easy on me
