compression
i still get 75 p.s.i., i was told if i pour a little oil (teaspoon) in the cylinder, put the plug back in crank a couple of times, and if there's a big difference in compression then the rings or the cylinder needs attention!! i done this and i went from 75 p.s.i. to 105p.s.i.
thanks again LT80,
shaun
thanks again LT80,
shaun
Will the engine start at all , or try to start 81dmc12 ? If not i would check the valve clearance before going any futher with your test ; if the valve clearance is off spec's it can give you an abnormal reading !....
Well, the coil is shot, carb was filthy, and while I was waiting on parts, I started tinkering with stuff. The guy I was working on it for just wanted me to get it running for now.
Thanks Williebee
Thanks Williebee
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Steeldon
Sep 9, 2015 09:38 AM
