87 lt230 quadsport
Old Oct 29, 2008 | 11:51 PM
jscan1020's Avatar
Default 87 lt230 quadsport
hey i just bought a 87 lt 230 and im refurbishing it i just took a part the engine because it smoked a bit i defiantly want to but a wiseco piston and bore it but what should i bore it to?? im looking to spent about 300 on the engine so what else should i do ?
thanks alot
Old Oct 31, 2008 | 07:10 PM
JustRandy's Avatar
You should check the rod. If the rod is loose (which it almost certainly is), your new bore job will wear out in about a year or so.... Depending how hard you ride it. If you opt not to change the rod, then bore it the minimun you can since you'll need to rebore it everytime it wears out again. And tell the machinist to make the bore as tight as he can. You need the very best work in this case!
lonerider856
Oct 13, 2023 03:45 PM
Valder
Nov 28, 2020 07:38 AM
fd24
Jan 16, 2019 08:59 AM
Nekolai1
Aug 25, 2015 10:04 PM
NatePerz
Jul 27, 2015 03:27 AM
