Z250 swing-arm replacement
Old Mar 27, 2009 | 07:09 PM
daquadfather's Avatar
Default Z250 swing-arm replacement
Hi folks,
Can anyone give some advice on the easiest way to replace the swing-arm bushes on a Z250 please?
I think the drive shaft needs to be split to do this?
Cheers in advance folks.
Old Apr 4, 2009 | 11:36 AM
My Z250 is "grinding" from the rear-end when I corner and I believe it is the swing-arm bushings that need replacing. Has anyone got any advice for me to change these as I believe you have to dismantle the prop shaft.
Cheers people.
Old Apr 5, 2009 | 09:22 AM
LT80's Avatar
LT80 Expert
Seeins the swingarm only moves a small amount, I'd look at the carrier bearings. Grinding in a corner leads me to suspect those.
Grab the rear tires and wiggle. See where it's moving.
toonces
Aug 5, 2015 05:55 PM
U2OFlyer
Aug 5, 2015 12:46 PM
toonces
Jul 28, 2015 01:58 PM
trouttracker
Jul 20, 2015 11:54 AM
jettman
Jul 6, 2015 12:16 PM
