lt230? models? any good?
Old Jun 15, 2009 | 07:08 PM
squirrelnuts's Avatar
Default lt230? models? any good?
i have a chance to pick up a lt 230 but i dont know if they are good for me. i own a lt 250r and love it. my firend has a 230 that has been sitting for about 4 years and hasnt been started. i told him i would give him 150 bucks for it. he agreed. i wanted to know how hard are they to work on? and what common problems will i encounter? any advise? (sorry no pics yet)
Old Jun 15, 2009 | 08:19 PM
faruquehabib's Avatar
for $150, you cant go wrong!
Old Jun 16, 2009 | 07:09 AM
LT80's Avatar
LT80 Expert
They are a good machine.
Old Jun 22, 2009 | 02:10 AM
bmk8's Avatar
Default lt230s
they are a great quad for only being 230 cc. I own three of them and all my friends like them too.
Old Jun 22, 2009 | 05:09 AM
Scooter86's Avatar
Knows Old ATV Questions!
Good little quads, they can go just about anywhere because they are so light. They certainly aren't powerhouses though, so don't expect it to keep up with the 250R on the straights. They aren't to bad to work on either. Actually, they have a lot of design in common with the '85/'86 LT250R.
Old Jun 25, 2009 | 09:48 PM
lt230sman's Avatar
230's are awesome little bikes.
reliable, TORQUEY, TORQUEY, TORQUEY (longer stroke than a 450!), light, more suspension travel than a blaster, reverse, hydraulic disc brakes all around, simple, kickstart
the main thing to watch out for on these things is the chain. what happens alot is someone will over-tighten it, and upon compression of the rear suspension, it will tighten and crush the swingarm bearings. then its all downhill from there. it becomes nearly impossible to keep the chain at the proper tension, and when it comes off it usually results in a hole in the sidecover. you gotta make sure the tension is correct, bearings, guides, and teeth are good, and it really helps to have a nice beefy o-ring chain (idk why but it makes a HUGE difference over non o-ring)
Old Jun 26, 2009 | 03:14 PM
Scooter86's Avatar
I would bet that is because the o-ring chains are internally lubricated. They don't wear as fast and therefore don't stretch as fast given proper maintenance vs the non o-ring style. Really, about the only place I see an advantage for the non o-ring is for racing or maybe a backyard quad that never sees inclement conditions. You don't really save much with them as you end up replacing the chain and sprockets that much quicker.
Old Jun 27, 2009 | 04:11 PM
lt230sman's Avatar
yeah that and it seems like the o-ring chains resist side-to-side movement (slapping around) much more than non o ring.
tmoose
Jun 30, 2015 08:28 AM
Shooterj2003
Jun 21, 2015 07:51 PM
hoopduerr
Jun 2, 2015 09:01 AM
hoopduerr
Jun 1, 2015 08:22 PM
neilbedwell
May 29, 2015 02:24 PM
