lt80 front brake
Old May 10, 2010 | 07:44 AM
burgezz's Avatar
Default lt80 front brake
I am trying to fix non working front brakes (purchased this way so I don't know what the issue is)...
The right front brake works but the left front brake didn't have an adjuster. I purchased an adjuster and have it installed but the adjuster is almost all the way out just to get the cable to react to the level pull... I think the cable may be stretched... does this require a new cable and is this type of thing fairly common?
Old May 12, 2010 | 03:36 PM
burgezz's Avatar
Anyone?
It appears to be installed correctly but is about an inch too long to work properly
Old May 20, 2010 | 10:04 PM
Twin LT80's's Avatar
You didn't say how old the machine is. Sounds like a stretched cable. They aren't too bad on ebay.
Old May 21, 2010 | 08:42 PM
LT80's Avatar
LT80 Expert
You can adjust the cable at the wheel too.
Old May 22, 2010 | 03:19 AM
hawaiianbasshead's Avatar
try pushing the leaver at the wheel and see if the thing for some odd reason needs new pads on just the one side. the leaver is where u adjust it anyway
Old May 22, 2010 | 08:27 AM
LT80's Avatar
LT80 Expert
Actually, you adjust at the lever and the handlebar.
Reactant
Mar 30, 2022 02:08 AM
greg74
Sep 10, 2019 03:03 PM
timster911
Jul 13, 2015 01:57 PM
tporath
Jul 11, 2015 12:31 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
