LT230 Project
Old Feb 21, 2011 | 10:10 PM
  #101
PinkFloydEffect's Avatar
Originally Posted by judas009
the one on the right has the indention's because most likely the valves were slapping up against the piston. could be timing issue or bad valve guides. could also mean the possibility of foreign objects somewhere ins the crankcase. i would definitely look into it before that engine gets fired up. maybe split it or flush it just to make sure.
My engine already has a good piston in it. But the one on the right's indications are machine made and symmetrical.
  #102
tomgodair's Avatar
The scoops are supposed to be there. The piston on the left is probably from a 2 stroke. Like an lt250r.
Old Feb 21, 2011 | 10:12 PM
  #103
tomgodair's Avatar
Actually, the one one the right is aftermarket (like weisico) the one on the left is oem
Old Feb 21, 2011 | 10:17 PM
  #104
Oh really? I know 4 stroke snow blower engines have a flat top like the left one. The one on the right docent seem that bad except for a tad bit of bending on one of the skirt edges.
Old Feb 21, 2011 | 10:24 PM
  #105
tomgodair's Avatar
They both look pretty shot. If you can run your finger nail across it and feel groves and its not smooth, they are probably bad.
Old Feb 22, 2011 | 10:46 AM
  #106
Trailrider230s's Avatar
Originally Posted by PinkFloydEffect
These are two spare pistons that came in the parts bin, obviously one is junk and the other is probably also junk. But why is one flat and one have scoops? Do they even go to this engine?
if they both measure 66mm they are 230s pistons. but they both seem to bet the same so i would say they are 230s pistons. one is a high compression and the other is stock. no way did one of them come out of a 2 stroke.
Old Feb 22, 2011 | 11:16 AM
  #107
tomgodair's Avatar
Yeh, I realized that after I posted it, thats why I re-posted the exact same answer above you. One is oem and one is aftermarket.
Old Feb 22, 2011 | 01:54 PM
  #108
the one on the right can be saved though. a slight grind work and polish and add a new set of rings, good as new. the one on the left i think is too scared up. looks like a piece of the ring broke off and scored it bad. i would hate to see the cylinder wall that piston was in.
Old Feb 22, 2011 | 07:02 PM
  #109
Basically I have two spare cylinders I was going to hone the better of the two and polish the piston on the right, sell it as a set on eBay.
Old Feb 22, 2011 | 08:09 PM
  #110
judas009's Avatar
hey pink are you experienced with clutches on the lt230 models that have the centrifugal clutch? i unnecessarily took off the release plate on my clutch when i split the case o clean out piston debris. i didnt pay attention to how tight the bolts should have been and now i cant tell if the tranny is shifting right. when i put the plate back on i tightened the bolts all the way down. heres the oem diagram
Rivamotorsports.com's 1985 Suzuki ATV LT-230GEF QUADRUNNER Parts List
the plate im talkin about is number 23. thanks for any input
