LT250R Overhaul Project
Old Jul 6, 2012 | 11:25 PM
  #221
PinkFloydEffect's Avatar
Thanks!
If I shut the fuel off at the petcock wouldn't it continue to drain the bowl into the cylinder during the 4 kicks?
I will post a compression test when I get the time.
I have painted an ATV with Fusion before but it chipped off easily, however I did not clear it.
The muffler leak was not due to the crush washer but possibly an O-ring? I used some maximum oil resistance Permatex gasket maker and the leak is no longer present.
Old Jul 7, 2012 | 01:30 AM
  #222
sporty982000's Avatar
Thats good you got the leak covered on the xhaust. Most of the time, you have to get a new alimuinum glasket for them.
the float bowl should have a over flow drain hose and screw to drain the float bowl for storing during winter. thats how I drained mine, when doing my compression check.
YA the only paint I found that does well with not chipping is laquer based paint or laquer clear coat. or a professional paint with a hardner agent in it.
Old Jul 7, 2012 | 01:33 AM
  #223
Maybe I can find some rattle bomb lacquer clear to go over the Fusion with.
Old Jul 7, 2012 | 02:19 AM
  #224
I get the stuff from autozone, works well, about $6.00 a can. but you will need 2 cans for sure. needs like 6 coats.
Old Jul 25, 2012 | 08:00 PM
  #225
Talking
Old Aug 3, 2012 | 10:00 PM
  #226
I completed rebuilding the rear shock and resi today, now the machine is complete. I took it for a test drive...woa what a difference those power reeds must make over stock in second gear it just takes off like a nut you blow right through it. I'm going to race my brother this week on his YFZ450r to see if I can get any advantage over him (long run and/or launch)
Old Aug 9, 2012 | 10:55 PM
  #227
Whiteboy98's Avatar
Floyd that is one hell of a zuke good work man one fine job
Old Aug 10, 2012 | 06:31 PM
  #228
Thanks! It's been a long time commin'
I'm having an issue though with coolant leaking out of the head, not a lot but just enough to wet the outside of the head gasket and an occasional drip (exhaust side) which dries right off by the time it hits the manifold. The head is torqued down correctly so I'm not sure...and the head gasket is installed correctly according to the diagram.
Old Aug 10, 2012 | 07:53 PM
  #229
scatto420's Avatar
this was the 86 with a 89 swing are swap?
Old Aug 11, 2012 | 11:00 PM
  #230
Yupp, 86' linkage and 87' shock with an 89' swinger!
