LT250R Overhaul Project
#31
Really? Damn you Dennis Kirk! I want one of those 4 way plugs I bet those are hard to foul but can you get those for small engines? I suppose I will be carrying a pair of extra plugs and a wrench with me under the seat for now on.
#33
I pulled the carb off last night, which I found much more difficult to remove the throttle cable from the box "slide" then a round 4 stroke. Will disassemble is soon, first I want to clean out the air passages.
#34
Get the racing NGK plug think it's a BR8Evg or something like that. It comes in a red racing box not there normal yellow. I put one in my 86 and Jt works well. They are like $8 though sothat sucks. Not like your normal $2 something.
#35
I'm going to buy one next time I make a purchase!
On a side note, my petcock doesn't shut off the fuel and spins really easily. I wonder if these things are rebuildable like a bad seal or if I should just spend the $40 on a new one.
#37
ya i went out and checked mine after you said something about the ngk and thats whats in mine that suzuki gave me to put in it the old one was from some lawnmower that someone els had in there lol
#38
This will be the first of two tear downs, this one lasting about a week then a complete thorough rebuild that will last about 3 months over the winter. I am just doing a good cleaning/degreasing and cleaning the vital components leading to the carb (fuel line, tank, air filter, box, and all airways) this is also a good time to find out what is going to need to be replaced. Currently I have my hillbilly 2x4" rear shock in place to hold the chassis up while doing work
Sure enough there WILL need to be replacing, check out this shock it's cracked. I have a spare but the bearings would need to be swapped, are these gas or oil? I need to drain the reservoirs or something, I don't know much about the seals.
The air box is pretty greasy and sticky, needs to be cleaned:
The exhaust leaks all over the inside of the rear fenders, it's missing a boot of some sort as the front pipe has. I am going to try a pipe clamp and some muffler sealer instead of the $20 piece that appears to belong here on CheapCycleParts.com
