1990 lt80
Old Aug 26, 2010 | 03:56 PM
john_david107's Avatar
Default 1990 lt80
I got a lt80 from my uncle and found that it turned over but would not run. Checked the compression and found it only had 30psi. installed a new jug and piston assembly. and still had to crank the machine untill it would finaly start. cleaned out carb and installed new carb kit. still machine had to crank for ever until it would start. when it would warm up machine would die. checked compression and i only have 30psi. I cant find a leak any were. any help.
Old Aug 27, 2010 | 07:49 AM
LT80's Avatar
LT80 Expert
I'm thinking it could be a plugged pipe.
Piston arrow toward exhaust?
Old Aug 29, 2010 | 07:40 PM
Default 1990 lt80
yes arrow is pointing to the exhaust. i did try and blow compressed air threw the exhaust and about half of air going into would come out half the pressure. tried and put sylicone on head gasket and compression went up to 80psi for a few secounds untill it pushed out of the head. ordered a head gasket and gona try and see what it does. any ideas on how to clean out the exhaust.
Old Aug 30, 2010 | 08:27 AM
LT80's Avatar
LT80 Expert
I put the pipe in my woodstove. LOL
You can use charcoal. get it red hot and blow air thru it. ****CAREFUL**** It'll throw flames.
Valder
Nov 28, 2020 07:38 AM
QuadRiders
Oct 22, 2015 04:13 PM
merryman
Sep 19, 2015 03:15 AM
Jaymc
Sep 11, 2015 07:45 AM
Bergmann
Aug 13, 2015 03:51 PM
