lt 250r carb adjustment question
Old Mar 1, 2012 | 09:11 PM
benzuki's Avatar
Default lt 250r carb adjustment question
hi, i just went through my mikuni on my 91 lt250r and set the mix screw at two turns out from the lightly seated position, per the book. i fouled the plug after a couple hrs ride time and its running a bit rich, is it counterclockwise to lean it or ritchen it, book dosent say? thanks.
Old Mar 2, 2012 | 12:41 PM
Doctorturbo's Avatar
GOT BOOST!
Ok, a few things here.
The idle mixture screw is just that; it controls idle mixture and not too much after that RPM. It has nothing to do with total fuel flow at speed; that has to do with main jets.
If you fouled plugs after a few hours ride you are way way way way too rich on your main jets. (If the plugs were fuel fouled and not oil fouled)
Take some time and read this artical:
http://www.motorcyclecarbs.com/carbs101.pdf
It's a great write up; you will like it because it answers your questions.
armpump450r
Technical and How-To Articles
Apr 1, 2017 06:11 AM
JBibb
Jul 4, 2015 10:16 AM
Ty Speece
Jul 2, 2015 04:59 PM
Joe04785
Jun 15, 2015 03:12 AM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
